androu
I've read through all the threads about engine problems with hard starting, etc. and the spark plug cap issue, and everything else I could find. I didn't see anyone else describing the exact problem I'm having, so here goes. At highway speeds, fifth gear, around 75 or so, temperature around mid-range (i.e. normal) I have experienced what I would call a lack of throttle response. The engine doesn't die or sputter, I'm just unable to accelerate, even with full twist of the throttle. If I gear down, I can get the revs higher, but still no increase in speed. It's almost like the speed limiter most newer Japanese bikes have now, execpt at around 70-75 mph. If I pull over and shut the ignition off, the bike will restart immediately and function normally, and I may not have the problem again for several days. It's happened about 4 times now and is quite sporadic, happend twice on one ride, then not agian for a long time. No engine warning light or any other abnormal indications, just lack of throttle response. Never happens until I'm on the road for a while at high speed, engine good and hot. I can ride around town and it never happens, only out on the highway at speed. Ideas? I guess I could swap out the plug caps since that's a known issue with at least some of the 2010 models, and it's pretty easy and cheap, but I'm not confident that's the probelm.
