After eight years and >100K miles the sun has taken a toll on the color of my speedo/tach needles, they are faded quite badly. Anybody ever repainted 'em? What paint did you use? Any caveats?
Gee, Jim... With friends like you, who needs enemies ;>)Mike, Ive heard that before and each time from some old person who's eyes are fading.
Aren't you glad you asked? - so you could get some helpful information.
Sorry to be a "smart A" but my wife has been in AZ all week and I have been without adult supervision all week.
Are you certain the NT's needles are translucent? The needle paint website cautioned you about that. If translucent needles are painted with their paint, they are dark at night. I presume then that the polycarb needles have the hot foil applied to the underside of the needle?Although most of my career was spent designing door panels, I spent 2-1/2 years designing instrument clusters.....Ford Exploder, Lincoln Continental....
The pointers are clear polycarbonate with a red 'hot foil' applied to them. Basically, kind of a mylar that is stamped onto the pointers, applied with heat and pressure. They are lit from an LED blasting light up through the shaft. This is called a 'light pipe', as the light follows the polycarb.
If you were to paint them, I'd suggest painting them semi-translucent red. The problem would be that they will be very blotchy when lit up in the dark, because you'll never get the paint applied evenly. Now, could you apply some transparent red plastic to them? Maybe....
If the battery has a full state of charge, there is nothing to worry about. Returning to the needles, the paint website did allude to the fact that it will likely take multiple coats of paint before the needles will be coated properly. I wonder if just a coat or two will be translucent enough to emulate the OE hot foil? Also, I try to avoid riding at night if I can and if I repaint the needles and just confine my riding to daylight hours if they will look much better. The light pipe effect is only apparent at night, correct?
