Just wondering if anyone has seen this. Noticed the counterweight that screws into the end of the bar felt wrong. It has unscrewed itself several times but this was different. Felt tight but still loose. Unscrewed the weight and got an extra piece of aluminum 6 mm or so with an obvious appearence of breakage. Seems the only thing holding the weight in was the last 3 or 4 mm to the long black screw that holds the weight in. More than half of the aluminum fitting that the screw goes into has broken apart. Glad it did not come loose in traffic. I would not want this weight bouncing around on the freeway. Will have to think about how this gets repaired.
