Rich
0
The other night I pulled into the driveway and discovered my brake and and tail lights were both out. These are two 1157-equivalent bulbs, with two filaments per bulb. At first I figured it had to be a problem with the wiring, since I believe these were all working the last time I drove after dark (yes, I confess I do not check all my lights every time I drive). But it turned out that it was all 4 filaments in the bulbs that somehow mysteriously blew out. Easy and cheap enough to replace, but it's a mystery. If they blew at the same time (unknown), one would think it was some kind of voltage surge event. But I've lost no other bulbs in the 11 months I've owned the bike.
New bulbs are working fine so far.
As it happens I've got a Hyperlight module mounted on my top box. This still worked, with no apparent problem, so I actually never totally lost brake and tail light function. Of course, the Hyperlight is fed from an electronic module which taps into the brake and tail light circuits right near these bulbs. I wonder if there's any possibility that the module caused some kind of voltage spikes in these circuits that blew the bulbs.
Keeping a closer eye on it, though checking that BOTH brake lights are working is a bit of work.
