I took my Connie tool list and am creating an NT list but I need a bit of help.....
Some things can be deleted here and I dont know the sparking plug socket size....
For instance, do I need a 19 mm wrench and socket?
Here's the list.....let me know of anything I really dont need....
NT tool set.doc
Screw driver set with bit assortment including standard, phillips, posi, torx, etc
Shorty screwdrivers Phillips and flat head and side wratched screw driver
Combo Wrenches: 8,10,12,13,14,15,17,19mm
?”- 3/8" drive sockets:7, 8,10,12,13,14,15,17,19, 22 , 27mm
?” to 3/8” drive adapter, 3/8” breaker bar
Allen wrench set and 3/8” drive Allen HEX BIT SOCKETS ,5,6,8,10, 12, 14mm
Metric hex combo set.
??mm spark plug socket
2 ea. 3” & 6” ?” extensions
27 mm closed end wrench with pipe extension
6” crescent wrench
Needle nose pliers
Internal and External ring pliers- 3/8" breaker bar (with 3/8" to 1/2" adaptor att.)
- 3/8" to 1/2" adaptor
- 1/4" ratchet drive (with 1/4" to 3/8" adaptor att.)
- 1/4" to 3/8" adaptor (attach to above)
- combo needle nose / wire cutter pliers/crimper
- channel locks
- Baggie containing:
- spare wire
- small assortment of electrical connectors
- zip ties
- electrical tape
- duct tape
Tire repair kits , electrical air pump and can of Tire Jack.
Volt meter
Gremlin Bell
NT tool set.doc
6” crescent wrench
Needle nose pliers
- channel locks
- spare wire
- zip ties
- electrical tape
- duct tape
Volt meter
Gremlin Bell
