Hi Wendell, if I'm still kicking next year I plan to be in Spearfish. Differences...definitely more power, somewhat more weight, I think the NT was 562 wet, before adding any accessories, this FJR is 639 (the Gen1 2003-2005 ones are around 610), better saddlebags from the standpoint of latching and that they can be removed from the bike, less fuel economy, not as flickable, better night lighting (2 low beam & hi beam sources with H4 bulbs), dramatically less vibration, more gas capacity 6.6 gallons, more engine heat but I haven't messed with the adjustable side cowl positions yet. Valve adjustments are shim under bucket type so camshafts would need to be removed - but valve checks are specified at every 16,600 miles. Now realize that I have only ridden it for 2 days. For me it needs bar risers, and a custom seat - most likely a Russell. I've had 3 previous Russell Day Long seats on my previous bikes and I really like them. Oh, the seat is a 2 piece affair so I would only need to have the drivers portion customized. And IT COMES WITH A TOOL KIT! Also the front forks (48mm tubes) are adjustable for compression and rebound damping and the rear shock is adjustable also.
