Omni-cruise
Seabee Rick
Has anyone tried omni-cruise? Is so, give me your thoughts?
It's basically a GoCruise taken to the next level and it costs $50 instead of $20. I have not used one but it appears to be well made and since it functions like the GoCruise I assume it does what you would want it to do.
I think it looks real good. I don't know if you could use a Vista-Cruise on an NT with Honda's heated grips. I think they'd be in the way of the hole you'd need to drill (which isn't that big a deal if the heated grips don't block it). It also looks like Vista-Cruise has fixed the biggest problem I had with it. They used to use a brass screw to adjust the tension and that screw would stretch and bend.
I think the Omni-Cruise looks OK, but I like my Throttlemeister and my Rostra electronic CC better, even if both of them are more expensive.
