I'm just going through this - many buy the kits and don't use them so figure I'd give some feedback.
Opinions vary - one rider races and uses plugs all the time.
I tried the Stop and Go which is a mushroom plug and while it would get a bike to a repair place there is still a slow leak - a bit less than what it was.... very slow but not trust worthy and there have been some negative reports on that style tho many ride it to the wear bars.
I have not been successful with the slow leak in the centre of the Pilot 3 so far with this kit.
I think it would easily have got me to a service centre the first time around. Sure learned how tough motorcycle tires are getting that plug in.
The string type seem a bit more reliable as it self vulcanizes. This was a good exercise as know what to do on the road at least to get to a service area.
Think I will get a Safetyseal kit from surveying the reviews of riders who have used both
ordered this one
Amazon.com: Safety Seal 30 String Pro Tire Repair Kit: Automotive
Tire Plug Kits, Fix Flat Tire, Tire Repair Tools | Safety Seal
Nother reason to have a water bottle along...find the leak.
I dont wrench and if I'm going to take it to the dealer I just put a new rear on.
The Strom will only be local riding for the rest of the year so will be a decent test for the SafetySeal product.
I think I might give the Stop and Go one more try to see if I can get it to work.
Seems when you stretch the plug back out to get the mushroom cap to be flat that's where it is hard to tell the correct amount of pull.
Pocket Tire Plugger - For All Tubeless Tires - Stop & Go International Inc Store
I'm not particularly worried on a slow leak failure - I'll keep the TPMS on all the time instead of just check.
This may be a good overview of both....might be the Stopngo method has made the string method impossible now but I'd rather have the string kit with me and I'll just use the Stopngo compressor.
Dynaplug? Tubeless Tire Puncture Repair Tools and Accessories
I think part of the fear that arises is by those that have not had a flat tire....it's not as dire as you imagine....these tires are very stiff and can run pretty much flat and still give you safe directional control.
One track rider noted that his but did 6 laps on a flat tire and came in third.
I'm pretty confident the strings will vulcanize - there are tons of ride to the bars anecdotes out there.
Not confident on the rubber plug tho....simply feels temporary tho once you've done one it's KISS to do.
ordered this one
Hmmm this looks good too - small and compact and can take multiple strings tho Safety Seal seems well proven.Like what others have said, I have not had a string plug even leak on me for 1000's of miles.
