Does anyone know what 9 blinks of the PGM-FI light, then off, then 9 blinks, then off means? As I start it, it now stays on constantly id that helps. This just started and I am seeking any knowledge I can gather. Thanks
If you've got a shop manual, it decodes the blink pattern. I can't find mine... I know I didn't give it away... but I don't know where it is. If I did, I'd tell you what's going on.
I think it is calling an air temperature sensor out of spec. I don't have much experience with the fault codes but that is what the book appears to say.
Have you done any work lately under the fuel tank? You might check the conections there.
