Problem with Ignition Key
North Falmouth Massachusetts
Looking for NT700
Went to start today and key was stuck in "OFF" position.After fiddling around with it for a couple of minutes I was finally able to move it to the "ON" position.The lock cylinder seems like its loose-doesn't have that solid feel.
Any help would be sppreciayed.
Salisbury,NC
Red NT700V & Spyder RTL
my key wouldn't open gas tank, had to use my spare. make sure key is not twisted, l needs to be flat and straight. if you need to straighten it, use plyers to flatten. key got twisted in the cylinder from additional stuff on key ring
Mechanicsburg, Pa. USA
I also have a key issue, about 50% of the time I have trouble inserting the key. Once in all works as it should. BB
I lube all my lock cylinders with Lock-Ease every six months or so. Makes 'em work real smooth.
