Punctures can be a real pain!
I had a puncture in my rear tire (PR4) about 6 weeks ago. As all the bike shops were closed I had to find a way of getting my bike home (about 30 miles). I could have called roadside assistance, but instead, decided to fill the tyre with gunk. This was because the tire was near the end of it's life and it would be best to replace it. The following day I got a brand new PR5 (more about the PR5 later) mounted and off I went.
Then, last week I got a puncture in the brand new PR5 - a screw just like the previous time. It had only done about 1000 miles! This time I was better prepared. I'd bought, on Amazon, a portable battery powered compressor. So time to try it out.
This thing works! It's a no-brainer!!
I just dialed in the pressure I wanted, connected it to the value and presssed the bigger red button (it has it's own battery so you don't need to connect it to the vehicle's battery.) The tire was reading 7.5 psi at start and a couple of minutes later it was at 42 psi. I didn't even need to stop it, it stopped automagically.
I got about half way to my local friendly dealer and decided to check the pressure. Yep, it was down to 28 psi. So out the pump came. It had remembered the previous setting of 42psi. So connected, inflated and off we went again. I got there before closing time and he repaired the tire immediately.
I guess it'll re-inflate a Deauville tire about 3 times from flat to about 40 psi before the internal battery gives out.
I'll now use it to check my tires every week and, because it automagically stops at the right pressure and has a quick connect system, I know my tires are at the correct pressure even allowing for a little loss of air when connecting! The gauge on mine is spot on with my other digital gauge, which I know is accurate.
It comes with both a car cigarette lighter charger and a mains charger, various attachments and some spare valve caps (brilliant idea). It also has a bag to keep it in.
I keep it in my side pannier as it's too big to go under the seat. I'm going to buy one for the new FJR as well.
I can thoroughly recommend this pump. It saved my bacon. Link to Amazon so you can read up about it: Oasser Tire Inflator
The PR5 is not as good on white lines in the wet as the PR4 was. It's an excellent tire but I think the PR4 was a little better.
