I’m thinking of buying a 2010 nt700v with low mileage. One curious this is the plastic parts are much lighter in color than I’ve seen. Are there variations? Or is this something to be concerned about?
Thanks, that’s good info.Hi Blueridge,
I haven't had an NT since 2015, but I think my experiences might help you. My NT was garage kept, but I did commute to work on it often. The motorcycle parking spot meant the right side of the bike got full sun all day. My plastics looked exactly like your photos until I "painted" them. It has been awhile, but you might find my old post on here with photos. I put "painted" in quotes because, I was worried about ruining the finish with a bad rattle can job, so I used a product called Plasti-dip. Plasti-dip is essentially a rubber paint in a spray can. This also means that it is not permanent. I think it worked great for the most part . I did have to redo one panel because it started to peel where I didn't get good coverage on an edge. The plasti-dip was still looking good when I traded the bike in, and it was not that faded grey color either. The plastics were just fine even when they looked grey. Painting them with plasti-dip or paint just makes them look new again.
I think if I were to do it again, I would find a good Krylon plastic paint instead, but the plasti-dip route might help prevent further sun damage if you don't want something permanent.
Faded grey plastics would not prevent me from buying another NT. The plastics in the back around the license plate might be the hardest to repaint, but the removable pieces were very easy to paint.
That is UV damage. No commercially available plastic restores will be able to revive it.
Wrong, Kemo Sabe. The Maxima High Gloss Coating works very well.
