samh
I just wanted to confirm that the 2011 NT700v has front and rear ABS? The spec on the honda site is confusing and leads to the conclusion that it has rear only.
Thx
Sam
Thx
Sam
Bob Higdon, legal counsel and historian for the Iron Butt Association, rides his second NT after putting 36,000 on the first one in less than a year, and after riding BMWs (mostly K-75s) for, oh, I don't know, probably 8-10 million miles or so. He got peeved when his last BMW's final drive failed in extreme rural Montana and the nearest BMW dealer was 4-500 miles away.I have a 2009 BMW G650GS.... Also the whole dealer-network thing is appealing on the honda. There is a dealership a cab ride from my house.
CBS does not activate the rear brake when the front brake lever is applied. CBS only comes in to play when the rear foot brake is depressed and then it performs a partial activation of the front brake...I don't believe this is correct. Both front and rear are activated by either brake actuator.
Sorry, lcseds, you are wrong on this one. The Combined Braking System on the VFR800 did activate a piston on the rear caliper when you used the brake lever, but the NT only goes rear to front with the combination.I don't believe this is correct. Both front and rear are activated by either brake actuator. Three pistons front and one piston rear with application of front brake lever. Rear brake pedal applies three pistons rear, one front. It not proportional. This allows performance riding by dragging the rear brake through a corner. Proportional would not allow this. Combined braking includes front and rear no matter what. But more braking force is applied with what you have selected to brake with (front or rear).
Actually, as far as I can tell, it works fine when you're doing rear wheel control braking. I don't do that as hard as some of the cops do, but when I've used it that way, it didn't interfere.SOOOOOOO....be very cautious if you try police officer rear wheel control braking to do tight maneuvers...it could spill ya...
Patt, whose book? books?I have just purchased your latest book...I am digesting it..Yours were the first books I read,before I purchased my first bike in '06.I also last week bought a "new" 2008 VFR with full GIVI bags and a top case.I went practicing...slow sharp turns using my back brake...then someone mentioned that perhaps that technique is not as effective if the brakes are linked....like my VFR'r are....your thoughts please....Sincerely Patt. M. Loo
From page 61 of the Owners Manual: "Your motorcycle is equipped with a Combined Braking System. Operating the front brake lever applies the front brake. Operating the rear brake pedal applies the rear brake and a portion of the front brake. For full braking effectiveness, use both the lever and the pedal simultaneously, as you would with a conventional motorcycle braking system."Both front and rear are activated by either brake actuator..... Combined braking includes front and rear no matter what. But more braking force is applied with what you have selected to brake with (front or rear).
Are they labeled as "Dual CBS"?I stand corrected. It is the "Dual" CBS found on larger bikes with dual front discs that activate a rear piston.
My ST1300 has Linked brakes, Front to rear and rear to front. So does the VFR And I can attest to the fact they work very well in conjunction with the ABSThey are referred to as Dual CBS on Honda's information about brake development.
To quote the paper on brakes:
"Dual CBS for large sports tourers
Honda has further advanced Combi Brake, which will work simultaneously on the front and rear wheels by operation of the pedal (left lever) only, to develop dual CBS for application to much larger sports models. Based on the front double disk brake and rear disk brake, this not only brakes the front and rear wheels at the same time by applying the pedal, but also applies braking force on the rear wheel when the right lever is operated. The dual CBS enabled to efficiently decelerate and reduce nosedive. "
Welll, there were two things that pumped. I thought one was my brakes. The other was a muscle near where I was sitting.HMMM Phil...was that possibly your HEART you felt pump??
