Right side hardware loose
Richardson, TX
My brother noticed that the housing on the throttle side that houses the starter button and throttle cable ends has about 1/16"-1/8" of rotational slop in it. I never noticed before. Is that normal or do I have something loose?
How do I tighten that if it is loose?
It's not normal. I'd look at the backside of the right handlebar switch housing. I'm guessing that there are two bolts/screws you can get to there.
New Mexico
KLR650, Red NT700V, YZFR3
I believe what you are describing is THROTTLE FREEPLAY, normal is between 1/16" to 1/4" yours is within the normal range.
I understood you to be talking about "slop" in the starter/kill switch housing, not in the throttle. If it's the housing, movement is not normal.
RedNigel
Richardson, TX
its the housing itself...I could only detect one screw on the bottom of the backside nearest me
2010 red NT 700, 1985 Kaw
There should be two screws that hold the housing. From what you said you need the front screw. Honda Part Number 93892-050445-07 or go to the nearest hardware store and get a 5x35 screw/washer. Metric of course and the screw and washer are together as one.
RedNigel
Richardson, TX
I found both screws but now I have to go buy a phillips that is short enough to get a straight shot at the screws without touching any painted surfaces
There's a hole on the underside of the handlebar on each side under the switch housings. A plastic tab inside the housing fits into the hole and positions the housing. That plastic tab may have broken off. On mine, I put a wrap or two of friction tape around the bar which is enough to keep the housing from moving when the two screws are tightened down.
Mine has always rotated slightly. That tab and hole in the bar keeps it from rotating any farther. It seems like a strange design to "pin the housing to the bar and not just clamp it tight like I have seen many times before.
Check the housing screws for tightness and if tight don't worry about it.
