Save yourself $250!!!! (Fork Guards)
Mesa, AZ
75 Honda CB360/Buell P3
....And buy the Triumph fork gaiters!!!
Sadly I was too late :doh1: I ordered and got mine the beginning of this month, set an appt to install them and my new tires. Then I noticed a small oil seep on the right fork tube before I took it in. My heart sank when I saw it and I knew I was too late! The labor to disassemble, clean and reassemble the fork plus parts was just over of $300. The gaitors were $60, they look great/work great and will save you the hassle of leaking seals.
On the other hand, the seal must have been leaking for a while with out me noticing because now I understand the comments of others on the forum about the front end being too stiff. Well it just took a bit to get use to is all. :D
I've got the NOJ (which stands for "No Ordinary Journey" on my NT. They work well
GLG
Phil/Joe - The Calif Sport Touring website doesn't say but I'm assuming these NOJ Fork Guards are one size fits all due to the hook/loop closure, correct?
As always, thanks so much for all the insight!
Gary
Gary
Yeah pretty much... just s strip of velcro.. you just wrap around and over lap one edge against the other. They won't fall off that's for sure.
I did run a zip-tie around the bottom of mine on the NT.
Got my NOJs today. Will give them a try. Not the prettiest things in the world but if they work, they work. Hey, I could get some gaiters, slit them up and down, and wrap them around the NOJs and fasten them on with cable ties! Voila!
BSA 441 Victor.
