androu
Well, I finally had a problem with the latches. I know this has been discussed to death and most agree it's not a good design, just thought I'd add my own experience to the pile. Stopped at the pharmacy to fill a prescription, went to stash my jacket in the left side box and it wouldn't shut! I got really frustrated and slammed it a few times, cursed under my breath and then took a deep breath and started trouble-shooting. It seems the "hook" part of the mechanism (under the seat) wasn't snapping back into position to recieve the "loop" portion of the latch (on the pannier lid). I took the seat off and pushed the latch back into position with a screwdriver from the inside, and was able to shut the lid securely. When I got home, I noted a lot of dirty grease built up around the latches. I dowsed everything I could get at with WD-40, cleaned up the mess, and worked the latches in and out about a hundred times with no failures. Worked OK today after my commute to work, but now I'm worried it will continue to happen, probably when most inconvenient. So far, it's the only thing I really don't like about this bike.
