So here's the list of farkles, planned and executed:
Wind deflectors - done. These were easy and they are very effective.
Tank Bag - done. Decided to go with Bag-Connections and Quick Lock mount from SW-Motech, available from Twisted Throttle. First bag was way too wide. Returned and got smaller bag, Day Pack II. You need a narrow bag to avoid the handlebars. Will put it on this week end and post pics. (see below for pics)
Seat - done. Ordered Sargent Premium Foam Upgrade which will produce a seat very like the World Sport. Should be here in a couple of weeks, will post pics. Received Sargent seat today. Will post review this weekend.
Horn - planned. Will likely use Stebel Nautilus from Twisted Throttle. Leaning toward also using the pre-fab wiring harness they offer.
Fuse Block - planned. Leaning toward the FuzBlock brand. Its a little expensive but only a few dollars more that others when you add a relay. Also, it is covered and sealed. Question, should I power the horn from the fuse block?
Fog/Driving Lights - Done. Likely (very) to use Denali lights. Small, lite, quality product. Mount is to be determined but leaning toward Morley Mount. Question, has Phil notices any ill effects ( wavering, giggling) with the fender mounts? Went with Denali D2 purchased in group buy on Two Wheeled Texans. Mounted to fender with Twisted Throttle kit.
Trunk - done. (Tentatively selected Givi V46 with Givi mount.) Re-evaluating. May go with Coo Case Astra S48. Case is complete with lights and signals, includes remote lock feature. With mount and adapter plate still $100 less than Givi or Honda. Ultimately went with JC Whitney. Same size as Givi E460, much less expensive.
Tail Lights - planned. Will likely use Admore LED lights with trunk. See above.
Bar Risers - Done. Installed MCL bar risers. Need became apparent on 500+ miler I rode. Sargent seat changed ergonomics to seat me lower and farther back than stock.
Any thought on priorities?
Keep the shiny side up,
Chuck
Chuck
