The farkling has begun in earnest
I know! People who just keep their bikes stock may save money, but they miss out on the fun. :)
silverdevil
you do not have a very big electrical output, I would wire the PIA's up before installing and make sure they work and check the overall voltage. you have to stay above 13v and I would stay above 13.5v if at all possible.
with nothing but stock I have 14.1v, with my LED running lights I have 13.8v.
you can not maintain the battery if it is below 13v when running down the road.
I have to turn off the LED's when below 30 mph.
johnha
All, only the switch is PIAA, the lights are LED's that each draw 20 watts. Being of a lazy sort, it was use that switch with its extended harness or re-invent the wheel.
Silverdevil, with the NT output of 452 watts I feel absolutely the electrical god, my '91 ST put out a peak 336 watts which was a step up from my '84 V65 Sabre.
