Wow, Larry! That looks great. If I was interested in pulling a trailer, that is the hitch and trailer I'd pull.
Good enough, I'll start keeping a list on this thread but I won't be able to place any orders until I get home after Spearfish plus a few days. Once I get back I can give my hitch to the fabrication shop to use as a pattern. You're #1, think Eldon is going to order also so I'll put him down.Thanks, Larry. That looks great. I'm in for one if you're taking names.
Yup I did. The thing is, since I've installed the lowering link gizmo I'm thinking that effectively places the preload down the same amount. Then when the preload is adjusted for the heaviest setting it most likely goes back to the equivalent stock setting, ie. no net gain. That's from the wisdom lips of a friend who chases such remote things down for publication. I'm going for a different tack next, going to raise the height of the hitch receiver to see if that has an effect. Also the tires are getting changed out Friday and that may have a positive effect on things. Hope hope hope.Larry,
Did you change the preload when you had the trailer connected?
Wowee, now that's an interesting piece of information, thanks! It's funny to hear that as the fabrication guy commented he'd like to have a heavier vertical rod but chose the one's he used to stay within the openings that are already present. I'm going to take it back to him and see what all would be entailed to widen them out and use heavier stock all around. It can't cost a lot and shouldn't require much shop time.Larry,
I figured I'd answer here as PM is not as fast.
I had a unigo on my ST1300.
It would wobble with aftermarket Delkevic pipes installed. The pipes are 2-pcs and have a band whereas the oem pipes are all one piece and use a welded tab to connect to the exhaust hangers on both sides of the bike.
The hitch you show, has 2 vertical support bars. I'm thinking they are not stiff enough to handle the tendency the trailer has to wobble.
When I had the hitch on the ST and the aftermarket pipes, I could stand on the hitch and push and wiggle it as much as I wanted to and it didn't budge, it felt as solid as it needed to be. But, at speed it would start wobbling, didn't matter if it was empty or full or what the tongue height was doing, I was afraid to ride it 10 miles. But, once I put the oem exhausts back I rode it to California without a single issue.
No sir, I have have, but may ST-Owners have and don't report any issues. I pretty much gave up on the trailer idea after the unigo because I ended up just packing more and more stuff and kinda like to keep things a bit less complicated.. LOLHey, Joe, have you used a 2 wheeled trailer, and if so, does IT also cause a wobble?
Hi Joe,No sir, I have have, but may ST-Owners have and don't report any issues. I pretty much gave up on the trailer idea after the unigo because I ended up just packing more and more stuff and kinda like to keep things a bit less complicated.. LOL
For me anyway..
The Sporting version hitch looks like it would do the trick but making something like that up to work on the NT is more than I want to get involved in. I'm going to pursue the two-wheel versions and see what can be used with my hitch as-is. Thanks again for sharing this info.Yes, the difference sound like it's in the hitch. The one welded to the scooter frame sounds beefier and much more solid.
The issue with the unigo is that you aren't just pulling a trailer, you're supporting it. The tongue weight on a unigo is many times 2 or 3 times that of a 2-wheel trailer... so, that will magnify any trailer issues as well as transmit them to the bike itself.
On a 2-wheel trailer you are supporting the tongue but you balance out the load over the trailer wheels so it's at a minimum... you actually just pull that trailer and support it just enough.
Compare a wheel barrel w/heavy load to a push cart w/same load... any imbalance or weak point while using a wheel barrel is apparent immediately but you can do just about anything with a push cart.
http://www.thirdwheeltrailers.com/index.php/home has a very interesting design which creates a good solid point of mounting... I don't have any experience with them though or know how easily something like that could be fabricated to get your unigo to pull better.
