I've found some info on this but not much help I replace plugs and caps didn't seem to do anything. Can't find anyone in the area to work on it (Atlanta GA.) It's a 2010 with just over 8000mi. I got a Honda for reliability. Can anyone help?
It runs very well until it’s warm typically stop and go cycling with the radiator fan.Does it run normally when started cold and then begin to act up when warm?
I’ll give that a tryTypically these symptoms are caused by the original faulty spark plug caps but you advise you have replaced these.
My next thought is fuel or fuel pump.
The other common problem that may be the cause is the crank position sensor but typically the symptoms for this problem is that the engine will not start when hot.
If it was my bike the first thing I would be doing is checking all of the electrical connectors under the seat (unplug and re-plug) as it could just be a bad electrical connection.
What kind of caps did you use to replace yours?Sure sounds like what mine was doing and was cured by putting on a new set of Spark Plug Caps.
Actually picked mine up at the local Honda dealer. They are specific to the bike and are available in other brands. Places can cross refference.What kind of caps did you use to replace yours?
This link should have the 3 page service bulletin about replacing the spark plug caps. Part number 30700-MEW-922What kind of caps did you use to replace yours?
Exactly what was called for in thisThis link should have the 3 page service bulletin about replacing the spark plug caps. Part number 30700-MEW-922
I'd be inclined to second this idea. When I purchased mine a couple years ago with about 21,000 miles on it, I discovered a problem. The bike started fine and ran fine, but when I got into stop-and-go traffic where the engine got hot enough for the fan to start to cycle, the engine would buck and miss. When I got back to open traffice everything was fine again.Your issue does not seem common so I'll throw this out there. Anything been done to the valves or checked the clearances?
Since it seems temperature related it could be possible a valve is too tight and when it gets hot expands, the clearance goes away, and then the valve never closes on it's seat.
This is a basically a longshot but if you have carefully checked the stuff suggested here it may be another thing to check to verify that it is not the issue.
Good Luck
I’ll try it and let you know thanksI'd be inclined to second this idea. When I purchased mine a couple years ago with about 21,000 miles on it, I discovered a problem. The bike started fine and ran fine, but when I got into stop-and-go traffic where the engine got hot enough for the fan to start to cycle, the engine would buck and miss. When I got back to open traffice everything was fine again.
As a hunch, I adjusted the valves and that cured the problem completely. Adjusting the valves is a pain, but that just might be the cause.
Cliff
I’ll try it and see thanks for sharingYour issue does not seem common so I'll throw this out there. Anything been done to the valves or checked the clearances?
Good Luck
