YKnot
Well, I finally got around to installing the large lids that I got from Redbird earlier this month. I thought I would be okay with the darker grey against my silver bike with black trim. However, with the scratches on the lids, the bike resembled more of a patchwork quilt. The solution was simple. Refinish the lids so that they matched the bike and eliminate the scratches.
The first solution that I tossed around was using "Plasti-Dip". The idea seemed easy enough: Sand down the scratches, smooth out the surface, spray on Plasti-Dip, and peel off any over-spray. However, after reading reviews, I determined that this would be a temporary solution at best. Plasti-Dip gives a dull (matte) finish that is easily scratched and easily removed and replaced. I needed something much more durable and long lasting.
Then I found kenstone's refinished lids. He used the spray cans of Dupli-Color Black Bed Liner (from NAPA). $12 later, I had picked one up at the local NAPA. After sanding down the lids to get the scratches out and allow for the bed liner to stick to it, I taped off the Dueaville logos and put 3 coats of bed liner on the lids. After letting them sit for 24 hours, I was able to put them on the bike, and I am impressed with how it all came out.
Here are some pictures of the process and end result...
Before:
Before:
