MarkAlann
Here in Indy it's been pretty hot and I've found the nt to be nearly too hot to ride. Seems the heat from the rear header either heats up under the tank or heats up my right leg. But I may have a solution and a way to test it first. I would like some one else to test with me and let us know the results.
What I did was remove the black plastic cover over the right side "bumper guard" and removed the small black plastic sheild just above the engine on the right side also. I did this just to see if the heat escapes and it seems to me that it helps, but looks bad.
If after a couple favorable test rides I'll make a scoop to force the heat out.
Does anyone else find the NT hot to ride?
