- Joined
- Jun 16, 2019
- Messages
- 667
- Bike
- 2010 NT700V
It sounds like to me that you are not building up enough pressure on the fuel rail to support the engine under a load. This could be directly related to fuel flow. A restricted fuel flow will not allow the pump to build up to the required normal operating pressure.
I would suggest that you do the Fuel Flow Inspection called out in 6-41 in the OEM Honda Shop Manual.
I really don't think it's fuel. His bike is running fine for half an hour or so. If it was a fuel presure issue that would be showing as soon as he hits the road. Also the bike is specifically complaining about TP sensor voltage with the MIL light.
I'm really betting on a connection issue. I went through this exact scenario a few months ago. Testing the TP sensor as per the shop manual is a waste of time. Get to the connectors, unplug them. Give a little spray of DeoxIT to the pins, allow to dry. Put back together and go ride.
