charlie b
First, let me say I considered the latches "backup" to the factory latches. Their strength is still limited by the plastic lip of the pannier lid. Probably a little stronger than the screws in the lid but still not overly strong.
If you want to use them as the only latch, I'd get some that attach to the lids a bit further in. This is a couble edge sword cause the lids have some ribs and such that could get in the way of a latch install.
Having said all that, here are pics of mine (not mine anymore
). Note: those two locations were chosen because they were the only two places I could fit my fingers in behind the frame portion of the panniers.
If doing this again I would make a slight change. I used washers as backing for the pop rivets that attached the latches to the bike. Instead I'd make special backing plates with holes to match. On the latches I used it would be a small place with two holes. This would spread the load a bit and make the attachment point a bit stronger.
I reckon! :wink: I do know I'll probably avoid any bike with fixed luggage in the future.
