OK you guys, you have made me go out into the sunshine and take some pictures.
The filter is the beige coloured plastic piece in the middle.
The red mesh at the bottom is the "strainer".
You can see how the gauge sender is attached to the filter at the top.
It would be near impossible to work around it to use a substitute.
One interesting thing I found was that the new gauge sender unit would only read the bottom half of the tank.
Although it mounts to the same points, the design is different to the original one and it would stay on full for 200+km before it started to move.
I had to remove the tank again and refit the original sender unit.
It is now back to normal.
