NCpkwyrider1
Are some of you changing your engine oil at some interval between 600 and 4000 miles? 3400 miles seems like a lot of mileage between oil changes. Thanks.
I knew I wasn't going to make it to the dealer at exactly 600 miles so I changed my oil at 450 to the oil I intended to use for the duration. At 900 miles I made it to the dealer for the 600. I'm not real scared of 4000. There are only two cylinders in there. Not 4 or 6 or 8. Yet, I've never gone 4000 on a motorcycle without changing the oil.
There is some argument against synthetic because most bikes use a wet clutch. I used dino on my last bike for 65,000 with zero noticeable engine wear but I sure love the idea of synthetic. If I go synthetic it would be until the engine is properly run in. I'd say 10,000.
Yes. The cost of oil and filter (10w-40 dino) at the dealer was $56.
Do you buy filters at the dealer?
No, I use the Wallmart filter ST6607. about 4 bucks. It has had some good write ups and it is also the same filter that my STuses. 50000 mile + No issues. Remeber Dealers are called Stealers for a reason.![]()
I understand.
Phil, at what mileage do you recommend switching over to synthetic? I've heard around 10,000 or so but I don't know how accurate that is. I used synthetic in my last bike after 10,000.
Ray, if you run your machine long enough to get up to operating temp for a while you flash off all the fuel in the oil. Short tripping will leave fuel in the oil.
I was changing my oil too often, am trying to reform. no it won't hurt the bike but we are wasting barrels of oil for no reliability gains...
I just picked up a case of Mobil 1 Racing 4T 10W-40 for the NV700. I used Mobil 1 Twin Synthetic 20-50 in my VStar.
As I have read this thread, it appears most of you seem to recommend switching to synthetic as late as 8000 to 12000 miles. On the VStar I did the switch at about 1100 miles.
What is bad about switching to synthetic at first service, at 600 miles? If your argument makes sense, I would be happy to put dino oil at 600 miles and wait with the synthetic switch.
freezingalaskan
