Hello! I hear a rattling noise when I ride over a bump or a dip on the road. I suspect it is the center bearing (I don't know what it is called). Has anyone worked on tightening the bearing? Or is it time for a bearing replacement. I don't have steering issue and when turning the handlebar from side to side, with the front wheel off the ground, I don't feel resistance and grinding. So maybe an adjustment is what I just need. This is not covered well in the manual.
What do you call that part of the bike which holds the entire front end suspension?
Thanks in advance.
Thanks in advance.
