- Joined
- Nov 7, 2020
- Messages
- 625
- Age
- 60
- Location
- Vienna, AuSTria, Europe
- Bike
- ST1100Y, ST1100R, NT700
Anyone ever had issues with the hyppoid gear at the tranny output?
When picking up my GF's NT700 in January I could feel & hear a slack in the drive-train in response to load changes...
After pulling the rear wheel I also removed the final-drive from the swing-arm but couldn't sense any excessive play or clearance there...
I thought I had fixed this then by replacing the worn hub-dampers & aluminum bushings, of course it has massively improved now, but there is still some metal(?) clacking noticeable...
And if I put the bike on main-stand, so the swing-arm is unloaded & hanging down, run the engine in idle and engage the clutch with 2ng gear to spin the rear wheel, some real clickidy-clack starts...
I plan to pull the swing-arm over the winter to check the U-joint and output shaft but wonder if I'll also need to pull the side gear case while at it... :unsure:
