- Joined
- Dec 23, 2019
- Messages
- 146
- Location
- near Harrow, Ontario Canada
- Bike
- '83 BMW R100RS & 3 XS650s
Just to back up what was said above about Yamaha clutches, I resurrected a 1976 Yamaha XS650C about five years ago. It was a genuine barn find complete with a layer of cow sh!t on the underside. The bike had been sitting for...10-15 years I think...and while the engine was free, the clutch was stuck tighter than a frozen turkey. So, I replaced the clutch cable, changed the engine oil, turned on some 1960s rock'n-roll, lashed the clutch lever to the handlebar with a bungee cord, put the bike in 5th gear and started rocking it back and forth on the garage floor while sitting on it and diggin' on the tunes.
After about 20 minutes I realized that I had moved about 3-4 feet away from where I had started and the clutch lever was much closer to the bars than when I had begun. Now I really got into it and within about 10 minutes, I was doing the Fred Flintstone shuffle all over the garage and the clutch lever was right up against the bars. About two weeks later I got the engine running (carb issues) and everything worked just fine! Since then I simply give the clutch a squeeze whenever I walk past the bike during the winter lay-up - and that is it.
As of Monday, I have put nearly 15,000 miles on that bike and have had no further clutch issues at all. I have never been inside the RH engine case-cover and never done anything beyond the occasional adjustment to the clutch after that initial freeing-up operation.
I will have to go in there soon to do the #4 starter gear change for which XS650s are famous (whenever I start it, the gears clash and it sounds like a teaspoon thrown down a garburator). It always starts - but the sound is....unattractive.
