NGK do not recommend the use of "anti-seize" on the threads as they are nickel plated for that purpose.
Yes, but heat-cycles and vibration can still lead to a crack in the ceramic insulator -> shunt -> no spark...The modern materials such as platinum and iridium just don't wear out much.
BTW, before i bought my 2018 Forester I test drove the turbo version. I wasnt that impressed, and the cost of the extended warrenty was significantly more with the turbo.I am finding that in applications where spark plug change intervals are around 60,000+ miles, they are extremely difficult to remove unless a never seize type product is used when installing them.
I have found this with different brands of spark plugs including NGK which I typically use.
I recently changed the plugs in my 2006 Subaru Forester 2.5 Turbo which has NGK plugs and a spark plug change interval of 60,000 miles. It took me around 5 to 10 minutes to unscrew each plug from the head which was partly due to the very poor access but equally due to how tight the plugs were when removing them and the length of the thread on the spark plugs.
What an interesting set of instructions! Completely different than from any US set of instructions. Almost like they are meant for the third world....Lubricating or failing to lubricate a thread contrary to specification, will result in misleading readings on a torque wrench. However, the instructions in the European Owner’s Manual circumvent the issue. Section 8 is significant.View attachment 17782
