been following the lowering threads and being short of inseam(the older i get the more i shrink) i've read where if you have access to machine shops, you can remove and mill down the stock shock eye. i assume this means you can mill it down to anything up to the 10mm of the aftermarket item. i have already lowered the seat 1/2" by taking a razor type knife and cutting the seat rubbers in half. worked great but i need a little more(probably not the full 10mm). maybe not even enough to have to cut the kickstand. any thoughts or collective wisdom??
