temperature gauge
Bikerboy1000
hi,
My temperature gauge is stuck in the one position, about one third up from the bottom on my 2007 700 deuville.
It doesn't go down when I switch off ignition, in fact it never moves
I have heard that on early deuvilles there was a problem with water ingress into the instrument panel and wonder if this is the problem.
I bought mine from a shop which is about 400 miles and is now just out of warranty.
Has anyone had this problem and is it an easy fix, thanks
It sounds like a meter issue since it is stuck even with power off.
Have you ever seen moisture droplets on the gauge face?
Bikerboy1000
There has never been a single spot of moisture on the actual instrument gauges
