I decided I wanted to try this and I knew I was taking a chance as their ads all stated
the pressure range from 0 to 50 psi and the temp range was -4 F to 176 F, also, you
can't adjust the front/rear hi/low settings but I typically set both tires the same so I didn't care so much.
However, when I got the item, there was an updated specs page added which
states the pressure range has been updated to 0 to 74 psi and you can now adjust the front and rear hi/low warning settings independently so those running different kinds of tires may love this.
I installed this on the Tenere as I needed to put new tires on and wanted to scrub those in
as well as give the TPMS a go..
I purchase this from Wingstuff.com for around $160.
Positives:
Negatives:
Conclusion
I give this a big thumbs up!
Positives:
- Price - at $150, it's probably the cheapest of the inside-wheel TPMS products.
- Monitoring - The longest I've seen it take to record tire pressure and temperature is about 20 seconds, fastest was about 2 seconds. You don't need to be moving forward for the sensor to record like other systems and it's not as long as several mins with other systems. The manual states it will take up to 3 mins to record pressure/temp but I've not seen it take that long at all.
- Sensors - These are sensors that looks like the ones that go in cars and it has metal
valve stems, the would easily mount to an NT wheel. - Display - The blue display w/white numbers is very easy to see in bright light.
Negatives:
- No angled valve stems - yes, only vertical ones however, if you know your pressure and it can be retrieved quickly, you're not going to have to deal with adding air or checking air as often so may be a wash.
Conclusion
