Thought I would post this to see what others have seen. My front brake wear is noticably uneven. The front right side calipers-as you sit in the saddle-are noticably more worn than the left. Now this got me to doing some testing. First I ran the bike up to high speed for a long time and then let it coast to a stop. Both front discs were cold. Don't think I have a brake sticking. Now I run up to speed and activate the rear brake only. Only the left front disc is mildly warm. This seems according to book. Then get up to speed and activate the front brake only. Left disc is uncomfortably warm but the right disc is way to hot to touch. Hhmmmmm. Now I get up to speed and hit all brakes as I am usually do. The front discs are only slightly cooler across the board. Now I get up to speed and hit all the brakes with a lot of pressure on the rear-more than I would normally think about doing. The fronts are notably cooler and the temperatures are balanced. Hhmmm again. Ideas? I would not normally use that much rear brake in routine driving but it did seem to balance out the front heat generation. Or is there a problem with the proportioning system. I am uncertain.
