Balanced Brakes? and uneven wear
It may also be that the pistons are sticky in the brake calliper. I am not sure if this is an issue with the NT700 but it is with some other Hondas.
The solution on other Hondas is to strip down the calliper and install new seals.
timonbik
Don't believe calipers are seizing up as they are releasing fine with no heat build up in the rotors. Pivot on lever lubricated, all ok. Switch???
