Electraclyde,
Currently I have the dip switches on my Rostra positioned:
1 - off, 2 - on, 3 - on, 4 - on, 5 - on, 6 - on, 7 - on, 8 - on, 9 - off, 10 - on, 11 - off, and 12 - off
I still need to experiment with switches 1 and 2 some more. I started with gain set on "High" and had nasty surging. I moved setting to "Mid" and dramatically improved the surging. The set/coast button doesn't work on my current settings, but I think that is a different matter. Pressing resume/accel pulls the throttle open and then kicks out and does not engage as speed drops back down to the set point. If I then accelerate back up past the set point and then reduce speed down to set point speed, the Rostra will then maintain set speed. I can set at and maintain 80 mph without the dropout you are having. I have not had an opportunity to get the tupperware back off to try some more switch combinations. Once past the "fiddly" set issues, this cruise maintains the set point very accurately. Let me know how yours turns out.
Update 2/12/17
Thanks Electraclyde for your persistence in finding the perfect programming switch combination (1-off, 2-off, 3-on, 4-on, 5-on, 6-on, 7-off, 8-off, 9-off, 10-on, 11-on, and 12-off). I'm amazed at how much time has passed since my initial install but, I finally pulled my tupperware to get the bugs out of my cruise control. I found the set coast button issue was switch 12 in the on position even though I had marked my notes as off.:rolleyes1: In the interest of saving time, I set the remaining switches to your switch combination. I then took my partially naked NT out for a run and the cruise works perfectly! It's really nice to have tap up/down available too. Thanks again.
