Yesterday, I was relocating the attachment points for the pannier lid tethers on Traveller. The mounting bosses molded into the pannier lid had cracked apart from the self tapping screws. I initially tried to rebuild the bosses using JB Weld but gave up after several attempts to rebuild them in a manner that would last. I then got some stainless hardware #10 machine screws, finish washers and nylock nuts and drilled holes in the pannier sides and attached the tethers in that manner. The screw heads and finish washers are visible but are very unobtrusive and really don't hurt the appearance. The right lid has always been somewhat mor difficult to latch closed and I am just days away from tearing into the latch mechanism and removing it and installing by exterior combination latches. However, when I tried closing the right lid I put pressure on the upper portion of the lid as I always have done and the lid cracked. Damn! The crack is about six inches long from the top of the pannier at an angle downward. Radiating from that crack is another horizontal crack about four inches long. The crack bisects exactly where I was going to locate the combination latch I was going to use. A cursory search of Ebay and OE Honda parts sources revealed that a new lid was unobtanium. I put a search request into a motorcycle salvage yard search tool but I am now looking into plastic welding. It won't look perfect but at 137K miles Traveller has his share of combat wounds so one more won't make any difference.
