Had the local dealer do analysis of the problem with their special tester. They gave me a nice printout [full diagnostic] saying an 8-1 code was logged = voltage low. Their bottom line resolution was to replace the throttle body. After they cleared the code, voltage was fine. I've been too busy to ride much but have seen the MIL come on at least twice, once with engine cutting out intermittently while under power. Last time it happened I just turned off the key hoping for a system reset and had no problem at restart.
Thank you to all who have shared their experiences and thoughts on this. I intend to provide updates as I work my way thru various possible solutions for benefit of others who face this issue.
Don, here are a couple of idea you may consider.
There is a used throttle body on ebay in Oregon. Here is
a link. $150 is cheaper than new, but a used throttle body is a little risky.
There are also used rectifier regulators on ebay for <$100 if you decide that may be a cause of your problems. A used regulator rectifier is a lot less risky than a used throttle body.
I have a good used rectifier regulator in my NT. Ride down to Yelm and we could swap regulator/rectifiers in about an hour. Whoever gets the next code 8 it would be 100% positive if your rectifier regulator is the cause. Disclaimer: I am only willing to swap rectifier/regulators if your
only electrical issue is the code 8 popping up. If you are having other electrical faults that are the classic "bad regulator/rectifier" symptoms like:
1) replaced the battery 3 times in a year,
2) lights dim, then bright, then dim,
3) burning up a lot of light bulbs
4) acrid smoke rolling out from under your seat or
5) "why won't my grip heaters stay on?".....,
I'm not interested in installing a strongly suspected regulator/rectifier in my NT in that case.
PM me if interested in swapping. I pulled my regulator yesterday, it can be done by just removing the seat and side cover. Don't get greedy though, I'm not volunteering to swap throttle bodies.:smile:
