taldric
My ignorance is showing... Where is the fuel filter on the NT? I've never found one.
It's part of the fuel pump and that is $222.95 retail. I am pretty sure it is just a mesh filter at the bottom of the in tank fuel pump.My ignorance is showing... Where is the fuel filter on the NT? I've never found one.
First thank you all
We picked it up Saturday and drove it home, cautiously encouraged because I had no problems. Wife worked all weekend so we never got it out for a long ride but for 15 miles it was good. The dealer said they found no codes stored and all systems checked out. They did consult with honda several times and they did do a test ride and did experience the problem. In the end they reset the ECM and pronounced it good. They said the goldwing owners have similar issues. They did the stride it some 35 miles and had no problems after the ECM was reset. A computer reset is not a very encouraging report but what else can one do at this point.
I will keep you posted on what happens next, I may be able to get it out one night this week.
First thank you all
Yikes Do you suppose they run Windows in the ECM?
I got so sick of Windows that I switched to LINUX--not as many whistles and bells, just good solid computing. Maybe Honda should stop using Windows as well.
so sick of Windows
That is good news.We took a 2 hour ride this past Sunday and the bike didn't miss a beat.
I guess resetting the ECM does something.
That is good news.
Do you know how Honda reset the ECM? It may be good information in case have a future relapse, you could reset it yourself. Did they simply disconnect the battery for set time & reconnect? ....or disconnect all the ECM connectors & reconnect? ...or is there a hidden/secret reset button?
If it was an intermittent connection on one of the ECM Connectors it would be quite likely that disconnecting & reconnecting can clean up the contacts and it would be permanent fix. Keep your fingers crossed. Good Luck.
My attempt to reset the ECM by disconnecting the battery overnight made no difference whatsoever. I made it to the end of my driveway before it started hesitating again. Back to the dealer tomorrow to see what the next step might be. This is getting pretty disappointing.
Kevin
