Hi, Phil.
I tried to answer your message but I got locked up in a timeout loop and I don't know if it went through. So I am also posting it here.
Fuel consumption?
I have yet to do any serious checking, but the way I ride on the road touring, I am seeing between 45 and 50 mpg. I think that with a little care, 300 miles per tank should be pretty easy. I would not want to try it, mind you. The FJR would be a beast to push. The FJR has an eight segment gas gauge. By the time the first segment starts flashing, you have about 1.5 gallons left. So the way I look at it, the FJR has a 5 gallon tank and a 1.5 gallon "virtual reserve". And remember, the FJR runs on regular gas.
The service intervals are very conservative. The U. S. book says oil change intervals are every 4K miles. The European book says the equivalent of 5,000 miles. U.S. valve check intervals are every 26,000 miles. One of the FJR sites did a survey of high mileage bikes and at 26,000 miles, about half were still in spec. At 78,000 miles, a quarter were still in spec.
Tire wear?
I have seen figures and estimates all over the place. I have seen a couple of reports of riders shredding stock tires in 4000 miles. Based on the way I ride, I may be able to get 15,000 miles out of mine, but more realistic estimates would be 12 - 14K miles.
What have I done to mine?
The previous owner had installed an MCL riser plate ($300) that actually replaces the stock upper triple tree clamp. It brings the grips up 1 1/2 " and back 1 3/4". I left it installed because it works great. This is the first bike that I have ever owned that didn't leave me with pain between my shoulder blades after several hours.
I had the dealer install canyon cages before I picked the bike up. Then I added custom sliders and later highway pegs.
I have installed a Garauld Engineering steel subframe stiffener ($115) to go with my Touratech luggage rack. Cracked aluminum subframes are not uncommon. I guess that is why the manufacturer's weight limit is only 20 lbs. If you are going to use a topbox, I think this is a good idea. Google "FJR cracked subframe".
Added a battery pigtail to power a tire air compressor. Also lets me charge the battery when I screw up and leave the key on overnight.
Next on the list is a larger windshield. The stock windshield looks great and is fine for putting around town, but for the road, it needs more coverage. Two popular alternatives are the Yamaha Touring Windshield and Cee Bailey products. This guy (Two Wheeled Obsession) did a comparison of the stock and Touring windshields:
https://www.youtube.com/watch?v=X4zZIZGlPEY&list=UUfWfFzjkrXx_HyJVzbBmUvQ
Two Wheeled Obsession also has a lot of diy videos about FJR maintenance.
I am not sure of a custom seat yet. For me, the stock seat seems to work pretty well.
John
I have a third generation (Yamaha calls it a Series III) '13A - the first year with built in cruise control. The ES model starts with the '14 models. Except for paint, there's no differences in the '13 - '15's. I am guessing that the used bike you are talking about is a '13. If so, $11,900 sounds a little high.Phil Tarman said:John, IIRC, your FJR is a '13 model. The guy I talked to today when I was looking at one said that as far as he knew there were very few differences between '13s, '14s, and '15s. I don't think I'd spend the extra bucks to get the adjustable suspensions. Eldon got it because he said he could lower the bike with it, but I don't think I'd need to do that.
If there are other differences, what are they?
What have you done to yours? Are there farkles that a person really needs? The things that I can think of off the top of my head are: a taller windscreen, the Canyon Dancer engine protection bars (and probably the pannier protectors, too), bar risers of some sort, and maybe sliders.
What kind of gas mileage do you get? The Yamaha website says 38mpg, which would work out to almost 250 miles/tank.
How long do tires last?
Does $11,900 sound like a good price for a very clean example with 11,900 miles?
What do I need to know??
Fuel consumption?
Tire wear?
John
