The NT has a shift arm forward of the footpeg vice the rotating shifting shaft coming out of the engine/transmission case near the footpeg as usually seen on bikes with heel toe shifters. I wonder if by adjusting the length of the tie bolt between the pedal and the shift arm, the location of the gearshift rubber would change to a position more comfortable for you to upshift?
