I did the installation on my grips last night. I initially purchased the grips (which comes with a wiring harness) and also the special wiring harness designed by Honda for the NT700, at an additional cost of $130.00 The instructions were well written, and the old grips were off and the new ones on in an hour.
Then I started comparing the two wiring harnesses. The schematics were virtually identical, excepting for the very terminal ends where it connects for power. The seperate $130 harness has a plastic two-prong plug-n-play. The one from Hondaline, which came with the grips, had two wire connections, marked Power and Ground. So what I did was splice another 48" of red and black wire, and plugged straight into a powered circuit in my fuse block.
Worked perfectly. So Tuesday, I'll do a return to the dealer of the NT700 harness, and use the money for something else. Total time on this install was about three hours.
