Is it perfect? I think we will have gas cars for some time yet.
No, it isn't perfect. The truth becomes readily apparent after driving an EV for just a couple weeks. Unless there is a quantum leap in battery technology, as well as charging methods and availability, I suspect most folks are going to avoid EVs. And not just for so called range anxiety. There is a significant level of hassle factor charging, especially if you don't have a "home" charger. I cannot visualize living in an apartment and having to chase public chargers as my only source of charging. I believe one of the Motor Trend writers is doing a year long test to see how well that scenario works out in LA.
That being said an EV will work for us, as our second vehicle, since it is only a metro area vehicle. And I can Level II charge at home and not need to be concerned about where my next charge is coming from.
Regarding Kona specific range here is something I discovered this morning. When we left for church it was only 40℉. My wife turned on the Heat and the estimated range instantly dropped by 30 miles. Turning the Heat off regained those 30 miles. The Kona EV uses a 6,000 Watt electric heater, not a heat pump or other source. The software is smart enough that when you turn on the heat it adjusts the estimated range accordingly. That is a nice feature. Running that built in toaster oven is a real power pig.
I found a neat window sticker. My wife has threatened severe retribution if I put one on "her" Kona.
