Hello All:
It's been awhile since I've been on the Forum, but I am riding more now and even camping once again pulling the Bed4One trailer I had built.
The posting might not be in the proper area, but wanted to pass along some hopefully useful information to others who might get a rear flat tire. I ride Michelin Road 5 tires and the other day I went out to start the bike and found a flat rear tire. Could not find the problem, so pumped it up and took off on some errands. By the time I started to head home I noticed the "wiggle" that I've learned means low air in the rear tire. Refilled the tire with my portable plug-in air compressor and headed home. Put the bike on the lift and kept spraying the tire, valve stem, bead, etc. Finally found a small stick had punctured the tire. Removed and tired to use the Stop-n-Go mushroom plug with no luck - tried twice! Tire was nearly new, but I figured since it wasn't going to hold air (still tiny air leak), it's worth buying a new one since I am only riding on 2 tires.
The learnings:
1. According to the dealer, the Michelin Road 5's are made of a silicon rather than rubber, so that might explain why I wasn't able to get the mushroom plug to completely seal - still not sure.
2. I started to do the procedure as outlined in the shop manual for getting the rear wheel off to take to the dealer and remembered that on my Lincoln Highway trip when I got a flat, I didn't take off the panniers or the muffler, etc. I double checked with the dealer and he confirmed I was right. My lift has a "trap door" so getting the bike on the lift and center stand, you can remove the rear wheel and also reinstall it without pulling off all the "goodies". The stop bolt for the rear brakes does not come out, but when it is fully disengaged you can remove the rear brake caliber and cable tie it up out of the way and slide the wheel down. Repeat in the reverse order to reinstall.
I didn't find anything explaining this procedure on either YouTube for the NT700V or on our forum. It works just fine and saves a whole lot of time and frustration removing old brittle plastic parts.
Hope this is of some help to others.
Remain safe, enjoy the ride and a SPECIAL big hello to Phil T! Hope we finally get to see you again at one of the NT700V gatherings soon.
Jim
The learnings:
Jim
