maxweljames
Received my new(to me) pans yesterday. Took an hour last night and did a quick sand on the slightly damaged R/H pan. 90% of the marks were only paint deep. A few of them did get into the meat of the material but cleaned up fairly quickly. After work today I cleaned it up, taped it off, and blew in some "Honda" Silver Metallic. I'm sure the label was referencing a Honda Civic because it sure doesn't match my NT(what did I expect for a $7 can from Autozone). It's a temporary fix anyways. This fall, once the outside temps drop, I'll do a full sand and spray with matched paint. For now it's an acceptable 10ft paint job covering a 15ft sanding job. Install was a breeze, 15 minutes to install both sides, so far the latches are flawless, fingers crossed. I've got a replacement "Deauville" emblem on order. $10 US dollars for a pair from Bournemouth UK, including shipping. Couldn't pass up that cheap of a price to complete my faux Deauville.
My personal thanks to Phil for dropping his NT a second time, giving me the opportunity to farkle my NT. Seriously though, nice of you to offer up you're stuff to us cheap basta.....um.. folk. Plus I'm a huge fan of recycling.
This heat we're having caused the paint to dry as fast as I could lay it down. So by the time I pulled the tape the paint was too dry to flow out, it was tape line city. I was so sloppy with this knowing it's all going to get stripped off in a couple months, really who cares. I can even make out a couple of swirl marks in the pic. That's what happens when you go from 150 grit to 600 grit and it's 115 degree heat index. This weekend I'm going to dig out the buffer and see if I can soften the paint lines a little. It might make the difference in color less noticeable.
