Is there a consensus replacement battery recommendation for the NT?
The reason for the ? above is:
My voltage monitor indicates a slow flashing green when the bike is running. This indicates the battery is receiving the proper charging voltage from the alternator (13.2 to 14.6 V). Which is good.
But when I turn on the ignition before starting the bike I get a yellow steady light which indicates acceptable battery condition, and/or poor possibly weak charging condition (12.1 to 12.4 volts).
Before starting, I have been expecting to see a solid green led that would show a fully charged battery (12.5 to 13.1 volts).
As long as I ride the bike frequently I have no starting problems.
However, a while back, I hooked up my Garmin mount directly to the battery. Went out to start the NT for a ride and heard the dreaded click, buzzzz, and no start at all. Not even a little turnover. Battery dead as a hammer. Did not think the Garmin hookup would drain the battery (GPS unit was not on the bike when this happened). I have since connected the GPS power to my Fuzeblock (as well as everything else electrical) and have had no further problems with the battery charge.
But in the back of my mind I still worry one day I will be miles from help and the bike will not start for me because the battery did not hold a charge.
So thinking about a pre-emptive move here and replacing the battery.
Am I needlessly worrying here?
