Rotella for the win, again!I've been using the Rotella T6 5w40 for 9 years now from freezing up to triple digits and I'm not changing now
Any thoughts on Mobil 1 15W -50 ... I just ordered some for my GS... Walmart has 5QT for $22...
I've used Mobil 1 15w50 a few times worked good for me. Last change was with Shell Rotella 15w40 full Synthetic seems to work good too.
ps Shell Rotella 5w40 full Syn. Never shifted smooth enough after a couple thousand milles so I like the 15w stuff better.
Ever checked/replaced the hub dampers?...i think the gear change gets a bit clonky...
Johnny, the viscosity you should be looking at is either a SAE 10-30 or SAE 10-40. Since it doesn't get too hot (or too cold) on the Emerald Isle either one would be just fine. The one specification you should look for on the label is to make sure that the oil meets JASO MA or MA2. This standard is for motorcycles with a wet clutch which your Honda has. Oils that don't have this label designation may have friction modifiers that are designed to improve mileage in cars and trucks but those friction modifiers don't play well with wet clutches. As far as the clunkiness, make sure that your clutch lever has about 1/4" - 3/8" freeplay at the end of the lever before it begins to engage. Shifting from neutral into first will result in a sometimes rather harsh clunk. This is just the nature of the beast. Once you are moving however shifting through the gears should be relatively clunk free. Having said that, as you begin to accumulate miles on the oil, the shifting will become somewhat clunkier. This is from the oil molecules shearing from the effect of the gears. It's not harmful, but when you do change the oil you will be amazed at how much smoother the shifting has become. You may use conventional or synthetic oil interchangeably, however I've found that conventional oil offers less clunky shifting for a longer interval than synthetic. The recommended change interval is 7K miles which may seem high but the oil still remains robust at 7K.Hello all i no you all say o no not oil again but i was glad Ron brought it up. Im not really shure about the differ say 5 or10 / 30 or 40. Snyt or not. But my bike was serviced before i got hur. Haven't even put 1000 miles on it since then with 10.000 on clock. But i think the gear change gets a bit clonky when she gets up to temp and hate that. Taking off in first woodnt be to smooth eider like clutch grip point differs. Shes my pride and joy and whant the best oil and filter. Here in Ireland they wi give you what they have on the shelf and tell you its the best and the more i read im actually afraid to change it or doing rong. Dont no what they put in before i bought but have to try something else. Shes a nt700v.
Shure does thanks mikeJohnny, the viscosity you should be looking at is either a SAE 10-30 or SAE 10-40. Since it doesn't get too hot (or too cold) on the Emerald Isle either one would be just fine. The one specification you should look for on the label is to make sure that the oil meets JASO MA or MA2. This standard is for motorcycles with a wet clutch which your Honda has. Oils that don't have this label designation may have friction modifiers that are designed to improve mileage in cars and trucks but those friction modifiers don't play well with wet clutches. As far as the clunkiness, make sure that your clutch lever has about 1/4" - 3/8" freeplay at the end of the lever before it begins to engage. Shifting from neutral into first will result in a sometimes rather harsh clunk. This is just the nature of the beast. Once you are moving however shifting through the gears should be relatively clunk free. Having said that, as you begin to accumulate miles on the oil, the shifting will become somewhat clunkier. This is from the oil molecules shearing from the effect of the gears. It's not harmful, but when you do change the oil you will be amazed at how much smoother the shifting has become. You may use conventional or synthetic oil interchangeably, however I've found that conventional oil offers less clunky shifting for a longer interval than synthetic. The recommended change interval is 7K miles which may seem high but the oil still remains robust at 7K.
Hope this helps!
There's only 10.500miles on hut st. Could there be that ware.Ever checked/replaced the hub dampers?
Ever cleaned/lubed the shifter linkage?
I'd further inspect/adjust/replace clutch-cable and replace the clutch lever if the brass bushing is worn...
