Thanks for the plastic molding education! It also seems that the plastic Honda chose for the panniers is more brittle and cracks easier than many of the plastics that I have dealt with in the automotive field. I know that a certain rigidity is required for the panniers so that may have been the best material available. Us EE's never learned nuthin' about plastics :redface:Y'all are learning way more about plastic part design than you had intended.
I don't exactly recall seeing the taper when I did my pannier work, but there is a certain amount of taper that is needed for the injection-molding process, so that the part releases and can be ejected from the tool.
One other lessons-learned is that if you put a very small counterbore on the inside diameter of the screw boss, it helps prevent a crack from initiating from the screw cutting threads into the plastic.
Anyone here want to start up our own motorcycle company? I'll be the engineer of the plastic bits.
