Thanks for the comments so far. Being accustomed to inline fours as well as the V4 in my GL, I'm wondering how you all feel about the Vtwin?
Riding ST1100 since '92, I got my GF a used NT700VA... she loves that thing to bits, riding Feb till Nov...
Rider/handling: seating position on the NT astonishingly comfy, brilliant rider seat, steering geos and handling uncomplicated and precise as an ST (typical Honda), excellent brakes, engine a little rough below 2400rpm and getting noisy above 4500... it's a 2 cyl... still astonishingly agile, of course not the easily "just throttle away" as a V-4 plant... a tad top heavy due the tank over engine concept, but lightweight once rolling...
pillion/seating: rear not as spacious as on the ST, passenger seat a tad hard, bumps pretty noticeable... aftermarket seats are avail though...
Luggage capacity is an issue... even with the deeper/larger pannier lids and a top-case installed it's barely enough for one when planning longer trips...
Technically it appears as reliable as an ST, similar rear end maintenance (lube splines with >60% Moly, check/replace hub dampers), have an eye on brakes and wheel bearings, flush (and I mean really flush, with lots of liquid, linked brakes with ABS modulator/unit in the center) brake system, fork oil, seals, bushings, head bearings...
Her NT had a little clicking on the rear shock, I first thought it's the needle bearing at the bottom and replaced it, turned out that the top mounting bolt wasn't fully tightened...
Also added some ATF into the hydraulic preload adjuster, as the knob required like 20 turns till resistance was noticeable... now it's two clicks from fully out...
Engine service a little complicated, access requires removal of the tank, fuel line features a quick coupling though (it's a Honda
Plastic air box cover held by self tapping screws, so care is advised upon re-installation: gently rotate counter clockwise till you feel the bolt's thread sinking into the old grooves, then tighten... failure to do so will damage the holes in the air-box... (such is a sign of the times, my good old ST1100 has brass inserts molded in the plastic and metric screws...)
PAIR plumbing and some air-baffles are in the way, forward cyl valve access requires removal of radiator... as with any transverse mounted V-2...
Adjusting valves straightforward, spanner/glider have wear indicators... they'll last for a couple of years though...
I installed new valve cover seals; my SOP, avoiding any oil seepage, and I'm not in the mood to dig in there again over attempting to safe on the rather cheap gaskets & gromets ...
Pannier lids and locking system appear to be a weak spot one should have an eye on...
The screw supports on the plastic can break; fixing/adding support with 2K epoxy advised...
Same on the bolts holding the limiter bands, GF broke them pretty soon... used some masking tape as mold, fill with epoxy, drill, re-tap the screw, done... annoying but fixed easily...
Locking mechanism (located deep under the seat) was blocked with gunk, lock barrel hard to operate (the keys that came with the bike had already cracks...), flushed with brake cleaner and cleaned with an old toothbrush, re-lubed with silicone spray/oil only... working fine and smooth now... I do that once a year though...
It stands and falls with the quality of service and treatment by the owner... if he/her is a fan of pressure-washers you'll see damaged wheel- & head-bearings, rusted in handlebar weights, etc...
If the tires got installed in a backyard shop, splines might be dry and rusted, hub dampers worn and loose...
I found aftermarket rotors and pads (latter even swapped in/outside during installation
), changed all to OEM, working flawless now...
Another thing I'd noticed: the starter always sounded pretty strained with AGM or geel batteries (EFI -> higher compression) requiring some cranking till it finally fired, occasionally it even took 3~4 times clicking the button till the starter even spun (yes I did clean and lube the switch-pods
); installed a LiFePO4 (NOCO NLP14) and it fires within 2 turns of the starter motor...
