Perhaps not common knowledge but there is a particular way to tighten the handlebar clamp bolts. The front bolts have to be tightened until the clamp is metal-to-metal which typically leaves a gap in the back. Now, the rear bolts are tightened and there is still a gap but that's OK.
If the clamps are tightened with equal gap at front-and-back or even worse, if they're done with no gap at the back, are more likely to come loose and move downward With no gap at the front, when the bar tries to move downward it pulls the clamp tighter because of the direction of force so they stay tight. The recommended torque is usually 16-ft-lbs and it doesn't seem like much but it works if you use this sequence of tightening. I'd take an education guess that all force applied on the bars while normally riding is downward...unless you happen to be doing a giant "stoppie" from speed!
There is a separate Honda motorcycle set-up manual (they are loose-leaf pages) for each model and every one I've ever seen in 20+ years give this sequence for handlebar clamp tightening. Handlebars other than those with a one-piece handlebar secured by 2 clamps/w 4 bolts, may require something different.
ps. this is not a procedure unique to Honda motorcycles and mostly likely, all the other brands recommend the same thing.
